Back in the day it was a matter of getting a really outstanding turntable, adding a top class power supply, placing it on an excellent stand, with top class arm and cartridge, optimal arm wiring and phono cable, really great set-up of all parameters like tracking weight, anti-skate, vertical tracking angle, azimuth, suspension, levelling, foot contact, a really good phonostage, optimally matched to the cartridge. Purity, clarity, dynamic impacts, naturalness, recording venue revelation and ability to move you deeply were the rewards. It was a fun time.
Today the kit is completely different but its exactly the same ballgameā¦.
Optimally designed and implemented dedicated mains supplies , complete internal and external vibration control, an optimally designed network (split modem/router, optimised router with Audio-dedicated 5GHz band or optimised Fibre Optics for isolation, exceptional power supplies and vibration control, carefully designed and executed network traffic management, carefully planned and executed cable screening, with a cabling chosen for accuracy and lack of colouration, ideally a loom of the same cable, for wi-fi installations a wi-fi to ethernet bridge, to take wi-fi activity away from the end device instead feeding it with voltage encoded, ācopperā ethernet. This is where the best cable goes!
And how does this all sound, when each stage of the network improves the signal and passes it on to the next to add its improvement. What improvement? Better vibration control, better power supplies, better powered vibration protected oscillators resulting in more accurate timing, less jitter and therefore phase noise,
Back in the day, the TT, arm and cartridge was āthe sourceā , Today its the network.
A bad network can have a profoundly detrimental affect on the hi-fi system as a whole, affecting not only remotely screened file replay, due to its effects on the CPU via interrupts, waits, network traffic noise, etc all levels of music are depleted.
A great network source on the other hand, along of course with a great supporting system can sound amazingā¦.basically like the turntable but with way less audible noise, allowing you to hear all the detail and refinement that the noise is hiding.
Basically, quite small improvements to the sound waves in terms of accuracy and lower noise that allow the brain to work more easily to achieve comprehension with less compensation and error correction, resulting in an even more enjoyable, completely immersive experience.
A major benefit in managing the network is in the fact that it is entirely scalableā¦.do a little, do a lot, do everything, using the most economical solutions, using audiophile āreported/recommended products, using the finest custom made products. But the key thing about a network is that it should be carefully thought about and designed to provide an interference and interuption free, high response data feed to your server or streamer. Thereāe nothing wrong with building an excellent network based on all-consumer-grade products. However its important to know that the quality of sound that results from that network, can be very very significantly uplifted in all areas by refining the network to the point the network stream is very close to the ideal spec. with very little deviation.
At the same time weāre doing this, give a thought to how the fixed and mobile devices that are the rest of our network traffic are best served. Personally I dedicate another 5GHz band to video streaming and have all mobile and a few fixed devices on 2.4GHz band
