If you buy, say, Chord Epic Speaker Cables from Futureshop, they offer 0-96 hours burn-in on a special ‘burning in machine’ for free! Yippee! (unless you like ‘burning in’ your own!)
I picked up a Shawline analogue interconnect, and initial feeling was that it seemed less detailed and much thinner (sonically) than an old Chord cable I bought donkey’s years ago. Maybe I should have gone for the Epic or higher. Just wondering really how much burn in time is needed.
Also I got phono to phono but maybe should have gone phono to DIN instead for better performance.
FWIW, I bought a brand new third party (not Chord) analogue interconnect recently and despite 2 weeks of playing Naim Radio on volume 1 most nights and some days, plus normal usage, it just never got any better and had to go back.
I agree, but if they’re no better than what I have already I’m happy to spend more if there’s a tangible improvement.
I have to ask why Naim don’t perhaps have a little room at shows demonstrating the difference powerline/powerline lite and varying grades of Naim interconnect make to a given system. This could be a bit of a cash cow at a show surely?
I’m not so sure Polarbear - I went to the show yesterday potentially (and secondarily) with a view to purchase lightweight upgrades I could easily carry home. I really (primarily) went to listen to speakers but ended up getting a modest cable and a turntable mat as I could buy them on the spot.
I have run quite a few Chord cables (power, ethernet and DIN in the past), i found there is not much of a painful burn in like some other products, it’s more of a minor refinement, tightening up.
I’ve been using 2 x 8M Chord Rumour 2 speaker cables for the past 15 years, and they produce a very clear and coherent sound - despite the fact that they are quite thin in diameter.
I wonder whether to get some Chord Odyssey or Epic? There are people who prefer them, but also a few who have been up the range and come right back to Rumour…
I got into a bit of a debate on a Facebook Linn Forum about cable burn-in. There appears to be no scientific evidence to support it, unlike speakers so I got well and truly hammered! I too had a Shawline on demo and didn’t like it either. I ran it for a couple of weeks before swapping out for a different manufacturer.
Hi, I used to think that a little burn-in is usually profitable for most of the hifi devices, may be it’s easier to understand this for cartridges rather than cables but that’s it.
Until, however, I bought a Vertere interconnect cable to use with my turntable to Stageline. From the first seconds it sounded so good that it was obvious it didn’t need burn-in at all. And it did not change afterward.
As to Chord cables I recently tried a Clearway and Shawline interconnect and I firmly preferred the Clearway rather then Shawline. It sounded more musical, signal seemed to flow freely, fluid rather than the self restrained Shawline. And it was ok from the first connection.
Bye
Alessandro
I have a Clearway too so may well be worth an A/B there.
The Shawline does sound good, just not sure if it’s much of an improvement over existing Chord interconnects I have - it also makes things sound a bit too ‘digital’ for me, others may like that.
