Thanks @anon4489532 suggesting a change to the set up of my components on my rack, which has resulted in a significant difference and improvement.
More detail, greater soundstage and the bass is deeper, but not overpowering.
Thanks again and enjoying this FOC upgrade.
This brings me onto to the next potential upgrade. I received today from my dealer a demo box of the Chord GroundARAY plugs which I’m now going to start playing with.
Have read some good reviews on this forum, so now it’s my turn to go down this road / rabbit hole…
I suggest that you try the RJ45 into your EE8 first Diggy. It’s the only one that I have after being told that it provides the most significant upgrade. It’s nice. I will be interested to read how you get on with the rest of them in your system.
No idea about a 100%. A half decent replacement switch would be a lot cheaper than one of these though. (And might actually do something, whether these do I doubt).
And they’d still be admitting an issue with their own ludicrously priced switch.
A friend brought over 3 Ansuz Noise Sortz Signature RCA plugs the other night. Plugged them into my 552 and the results were impressive. Lower noise floor, more music. I was impressed. I plan to try the Chord Groudaray’s next for comparison.
