I’m currently using a Chord Powerhaus P6 with the standard mains lead and looking to upgrade the mains lead, any recommendations please at a cost in proportion to the block.
I guess it depends on the rest of the system as well. I’ve got the S6 and started with chord shawl one which was much better than the stock cable. Moving up to the epic range was also a good upgrade. If I’d have had my time again I might have thought about where I was going to end up with the system after upgrades etc and specified accordingly. You can always sell them on but the connector needed at the powerhaus end isn’t particularly standard.
Thank you I was considering the Shawline or possibly the Epic at a stretch. I’ve heard that the Isotek EVO3 could be an option also.
I think the Isotek EVO3 is discontinued. I am using the Sigma 5 with their power cords and really like how it reduces the noise floor.
Thanks for the info. I was looking at the Sequel.
Is it called Sigms?
Isotek EVO 3 Sequel.
With a M6 I have very good results with a Neotech NEP 3001 II Cable, self terminated with Viborg Plugs.
This one was way better than for example a Chord Signature (not the X version!)
Thank you for your advice, very much appreciated
