Chord - ShawlineX vs OdysseyX speaker cable
Hello all. I own a few Olive Naim pieces. NAC 82, NAP 180, HiCap, SBL mK2 speakers and Shahinian Compass mK2 speakers. My question to all is which speaker cable would be best between ShawlineX and OdysseyX. Please note I already own NAC A5 speaker cable so looking for additional cable for either speaker as would like to run both (not at the same time) without having to change cables etc. I did have ClearwayX but it became faulty and Chord are replacing it and offering to upgrade it to either. The speaker cables will be 5 metres long. Would value your thoughts. Fantastic service from Chord.
I’d stick with NacA5 and buy some music. :wink:
If it’s a free upgrade it makes sense to get the more expensive Shawline. I tried Odyssey for a while and found it uninvolving.
In contrast I found the old Odyssey my best SQ pick from NACA5, Linn K20, QED (??) and Mogami (?) and I still have it.
I measured the C and L (as Chord don’t publish) and found my 5m of Odyssey were close to the Naim minimum 3.5uH. And that is more important for your NAP180 than my Supernait.
Thank you for this information. So OdysseyX is similar to NAC A5. Presumably more expensive doesn’t necessarily mean better. The more expensive being the ShawlineX. If I one day changed to a NAP 250 would that make a difference regarding speaker cable?
NO I did not say OdysseyX is similar to NACA5.
What I said was 5m of Odyssey is approximately (a little less, in fact) the same L (inductance) as 3.5m of NACA5.
