Chord ultima side cheeks
Does anyone have any real world images (not pack shots) of the chord ultima amps with their ‘side cheeks’.
Are they interchangeable with the feet? So, I could swap if I wanted to change my configuration and stack the units in the future?
You specify which ones when you buy. I can’t see how they would be changeable by the user. You’ve made me realise now how much dust is behind my set up!
This help?
Thanks, I’ve got an ultima 5 on demo, but I’d like to see some images with the optional side blocks.
Get your dealer to borrow them from Chord……if he can’t be bothered-go elsewhere
You asked
Thanks all, some cool Ultimas here! Does anyone have them with the option acrylic sides like the image below? (Ideally in black)
I asked chord about this when i got my ultima 6 and they said it would have to go back to them as there is wiring through the feet
