Hi
Can anyone help? I’m trying to connect my Hicap to NAC 82 and NAC 250 and have a problem. I have no user manuals so I got one online which shows the far left hand (looked at from the back) DIN socket on the 82 out to the Hicap. On my 82 this socket is labelled “Link 1 - P/S 1”. The guide then shows the connection from the 82 going into the Hicap at the far right hand socket (opposite the mains input) and the 250 connection going into the second socket in from the right. However, my Hicap is a Chrome Bumper version from 1985, and its sockets are labelled from the mains input 1-4. Written at the bottom it says “Socket 2 to Amp and Socket 3 to pre-amp.” However my connections guide is telling me to put the 82 into Socket 4 and the 250 into Socket 3. Socket 4 also says "To equipment marked Hicap. Can anyone tell me the correct connections please?
