Clean Power
Dear Naim Community
My apartment has a weird electrical system. Instead of alimenting power from single phase, I have 220V double phase, 110V from negative and positive lines. The grounding is ok though. I am not sure how clean the power is as well. Which power gear should I add? I am considering power regerenators from PS Audio, or isotek sigma. But I am not sure especially considering how sensitive are Naim products to power. My system is as below
Naim SN3 with Hicap DR
NDX2 with 555DR
Kanta No2
RegaP8
Project RS2 phono stage and power box
Laiv headphone amp
Hifiman HE1000
Where abouts in the world are you ?, and what voltage is your system set up to use ?
Some more information will be needed:
  • What country are you in?
  • What makes you think your current mains setup has a problem that needs solving? If you aren’t sure if the power is clean, it’s going to be difficult for anyone else in make any recommendations.
Hey;
I am in Barcelona. 230V standard I have.
You have 230V in Spain.
The humm on my hicap dr is really high. I am hearing it during night sessions from my listening position. I put an ifi dc defender but nothing changed. I am also using a power strip from Audioquest. Powerhouse 6
Unless you have a balanced power supply, you shouldn’t have both positive and negative giving 110v each.
Thanks @kitfit1. So should I look for balanced power regenerator?
I think what you should look for is an electrician! In my limited understanding, if you’re seeing 110V x 2 rather than just 220V you already have a balanced supply, so you need to be careful what you connect to it.
My thoughts exactly. There is no way the OP should be seeing 110v on both live and neutral on any supply to his property. An electrician should be able to sort this out.
A “balanced” power supply is something you add to the mains after it enters your property.
:thinking: thanks for the advice.
Is it possible he somehow has a split single phase 240V electrical system, like we have here in the US, but with the neutral just wired as safety ground? Might explain the buzzing… Also sounds wildly unsafe but I’m not an EU electrician.
Over here in Belgium, several (older) houses, including mine, are using a strange 3 x 230 V three-phase system, where the voltage difference between each phase wire is 230 V and there is no neutral conductor.
Phase to earth is ~130V in this case and each phase is 120 degrees apart. This is different to balanced power where the two phases are 180 degrees apart (and phase to earth would be ~115V).
Maybe it’s something similar in Barcelona?
indeed it is. The electrician told me exactly the same. When I check some other articles, some people are suggesting Power Regenerators.
