Cleaning mode - HDX
The message Cleaning Mode Please Wait… has appeared on the screen of my HDX. No idea why. Does anyone know how to get rid of it? I’ve looked all through the settings and even the manual and am none the wiser.
@ChrisSU maybe.
When I select Cleaning Mode it goes back to the previous screen after about 20 seconds.
Maybe try a restart?
Found this in the manual if this is any help.
DG…
Sorry, no idea why you would see this, unless you had navigated to that option. It’s there to temporarily disable the touchscreen so that you can clean it, but as far as I can remember you have to navigate to that option in the menu and it lasts for 30 seconds, then reverts to normal.
Had to restart. I must have engaged it by mistake and then it froze (because Windows, I guess).
