Connecting 2 headphone amps to naim NAC 202
Hi,
I have a naim headline headphone amplifier connected to the 5-pin din tape out socket of a NAC 202. I would like to connect another headphone amplifier with RCA inputs and outputs to the same NAC 202. Preferably using fixed-volume connection since both headphone amplifiers have a volume knob. Any ideas how? Is there a preamp out? What cable - connector would I need?
Thanks and best regards,
Walter
Look at the back side of the NAC202, there are three DIN sockets with in/out. You need a DIN 5/180° to RCA interconnect (with 2 OUT or 2 OUT & 2 IN - as for TAPE devices).
emphasized textDo you mean that I should connect one 5-pin din to rca from one “out din socket” to each of the two headphone amps?
Yep, same way you did it with the first headphone amp, but with RCA plugs at the other end.
