I ordered new 252/300 / SUPERCAR CAP to upgrade my 282 / HICAPDR / 250DR.
I would like to prepare to upgrade stock cables for new components.
I would like to replace the stock cables and in particular the 5 pin cable to connect 252 to the Supercap and the two XLR - 4 pin din cables to connect the NAP 300 to the Supercap.
What high quality alternatives can I buy besides Superlumina?
I replaced Super Luminaâs with Chord Musicâs and a Sarum T. For a short period I had an Ansuz A2 DIN/DIN from my ND555 to NAC 552. It was excellent.
The Super Luminaâs were excellent for that matter.
Performances of these cables pretty much reflect their price points.
Youâll get cables included with the system, except for NACA5 which you have already. Why not let you and the system settle in on stock cables before trying alternatives. Itâs good to have a baseline and sometimes returning to it can highlight what can sometimes get lost when making changes. There seems to be some speaker dependancy when it comes to cables too, the ones ending in BL do quite well on the stock cables.
Discussing alternatives to power carrying cables like the Snaic is against forum rules in any case.
Good advice from Yeti. The new components will take you on a bit of a journey as they âburn inâ. It would be very sensible to stick with what you have for at least a couple of months. Get used to what you now have in terms of sound quality to establish a reference point.
After that, the obvious competitor to Super Lumina are produced by Chord and at SL level these would be either Sarum T or Music, depending on how deep your pockets are. One thing to consider is speaker cables and interconnects you are using for your components. I havenât dappled with this but I recall a few forum members expressing the view that Super Lumina shows off its best when forming a loom ie there is a benefit to use of SL throughout your system. Hope these comments arenât dragging you off on a tangent but may be worth discussing what is available for loan with your dealer to help decide on a strategy however, long term that may be!
Peter
PS Like Yeti, I would not advise on introducing curry to any hi-fi system!! (Sorry!)
Above is all good advice but I wanted to stress that as you have new boxes you should just stay with the SNAIC cable as youâll need to protect the warranty in case there are any manufacturing defects.
In future youâll need to be aware you might have full responsibility for any performance issues if you change this cable and IMO itâs just not worth it.
On the rest of the loom staying with Naim Cables also keeps you out of the rabbit hole of forever looking for the âbestâ cable from the infinite possibilities that all sound different but might not be better.
Fantastic system and you are going to love the music if you can put upgraditis aside.
