I’ll soon be adding a second HicapDR to my wonderful 282. Although I do have the diagram which seems straightforward, I want to make sure I’m not missing anything and moreover avoid damaging something.
I understand I need to remove the plastic cover in order to connect the second HiCapDR but I was wondering if there anything I need to do with the 5pin cap that came in the 282’s accessories bag (picture attached). Also, does the socket highlighted in the diagram remain open / unconnected?
Nope. No need for any plugs when connecting two power supplies. Link 2 can be left as-is with nothing in it. You literally do only what is shown in the diagram.
Looks good to me.
It gets marginally more complicated when the 250 becomes a 300.
Last strip and clean I did left me with no sound due to HiCap connections being the wrong way round🤷🏻♂️
Can I ask a question regarding the benefits of the second hicap, it’s something I have thought about doing for awhile but feelings on the forum seem very mixed, thanks for anyone’s thoughts.
Well since the output is not balanced, you might as well go DIN to RCA to the speakers. XLR is not really helping unless it is a balanced connection.
If the lead is long, you may need it slugged with a resister as the Naim is not designed to drive long interconnects. Naim generally recommend a resister over 3m length but it seems there are others on the forum who have gone up to 5m and not upset the HiCap or preamp.
