Hi, i want to connect a 32.5/hc to a non naim power amp. I believe i need a 4 pin din to rca cable, but which high cap socket do i use. Is it socket number 1, 2, or 3?
Sockets 1, 2 & 3 have the same pin-out, so I’m not sure it matters much. But the printing at the back says socket 3 for the first passive amp, so I would do that:
Hi, thanks for the reply. My hicap is a cb one and the rear panel is slightly different
Not sure i understand why you would connect socket 3 to a preamp when the pre is connected via socket 4?
Use socket 2 on CB HiCaps, socket 3 carries power.
Hi, thanks for the info. I thought i’d ask the question rather than risk experimentation!
Ah I should have noticed.
