Hi Richard, please can you re-open my topic: “New MC Cartridge” as I have an update.
I also have a question re my Naim Prefix:
How do I connect the earth cable to a NAC-N 272?
Re-opened for you.
As for the NAC-N272, there’s no earth post, as you’re no doubt aware. But the first question is whether you need to connect it at all; you may be fine without. Otherwise you may need to connect some other way to the chassis of the 272 or Hicap.
Thanks Richard. I’ll see if I can get a crocodile clip to replace the loop, if I need to connect the earth cable.
