Thanks for this forum hope you can help me get my head around this…
I have a basic Naim system for my apartment comprising of Nait 5 (not i or si) / Flatcap2 / B&W speakers / CD3.5 and I would like to put Rega Planar 1 Plus turntable to the system but I cannot work out how to…
If the Rega Plus with a built in phono stage can be plugged directly into the Nait 5 or flatcap2 ?
I guess a phono to din lead would be needed.
If it can be plugged into the Nait5 would it be in the AUX2 socket (RHS side as you look at the back), I assume not plugging into AV, AUX1 will work ?
Or any additional information would help
Or cannot a turntable with a built in phono stage work, so a standard Rega Planar1 and stageline N would be needed plugged via the Flatcap?
As Neil says above, any turntable with a built in phono stage is basically a line level source same as a CD player or streamer. You can also use a turntable without a phono stage with for example a stageline (suitably powered).
I’m new to the Naim discussion and write here because I’m also looking for information regarding the Rega Planar 1 Plus turntable. Can this turntable (or any other) be connected to either the Naim Mu-so or Mu-so QB (first generation). When I bought them (I have both) I was told that connecting a turntable is an option, but now I’m not sure. Any good information is appreciated.
