I am thinking of connecting a second TT to my SN3. The current phono input is already taken by an RP6 via RCA phono. There is a used Naim stage line (N MM) phono available for sale online.
Reading the manual is confusing, as there is no (aux 2) din input, only (aux in&pwr) at the backside of the amp, and the front has the aux button. Is this (aux in&pwr) din input the right one to use with a Naim N mm stage line phono amp?
The used Naim stage line comes with a Non-Naim 5 Pin din cable.
The Stageline should come with a SNAIC5. I would not use anything but a genuine Naim SNAIC here. A Stageline without should be priced accordingly so you can buy a genuine Naim replacement.
A new Naim stageline is around AUD$1K. If I were to buy a genuine SNAIC5, probably be better off getting a new one with warranty. Thanks all for the information.
