Connecting CDX to NAC-202 via Naim . DIN connector
Hello,
I use Naim NAC-202, what I want to ask is that this NAC-202 has 2 CD input options via the Naim DIN connector and through the RCA connector, is there an option / switch that regulates which connection we use from the CD, whether it’s RCA or DIN?
please help
thanks
Hope this helps!!!
hello I just read the same case as me and I connected it to the manual book NAC-202 and it turned out that only the CD input settings to DIN or to RCA/Phono via Program Mode, by pressing the number 1 on the remote for a while and it will switch input between DIN or via RCA Phono
Thank you to all of you
Did you buy the 202/200 in the end!?
Yes, packed with NAPSC and Hicap DR
Awesome - enjoy it 8)
thank you, sound is incredible, love Naim…
earlier I have successfully moved input from Phono Input (CD)-RCA to CD-DIN Input by holding down button 1 in program mode (red line), I want to make sure for button 6 in program mode whether to move Phono Input (AUX 2)-RCA to Input Aux-2-DIN by holding button 6 in program mode (yellow line) is this correct according to what I drew below ?
anybody have thought about connection picture above?
