Connecting NDX to 282
Which is the preferred DIN input for connecting an NDX2 to a 282. There are none labeled ‘streamer’ so I am guessing Aux ?. Does it really matter, I can not find a definitive answer?
CD, Tuner & Aux2 inputs are all the same, so pick which ever works best for your set up.
The others can be used but have other connections such as tape in/out or power
As per @Mike-B comments, CD, Tuner, Aux are all OK. I route my NDX2 into the CD input of my 282 and it works just fine.
cheers
Thank you.
:slight_smile:
