Some advice if I may…
Currently running the Nova into my Kudos X2’s and enjoying the music.
Previous system was a 172 / 250-2. I have sold on the 172 but still have the 250-2 so was going to hook it up to the Nova just to see how it sounds. This is not about upgrading as such (although I see on some threads that some have connected some pretty beefy power amps to their Novas) but more as an ‘try it and see’ just because it’s there. I may well sell on the 250-2 yet.
My question is connecting it. I obviously have the snaic that came with the 250-2 … will this work?
I assume I could also connect 2 phono - 2 phono lead. Will any phono lead be ok?
Also will I need to change from default to floating?
Just want to make sure I get it right.
Many thanks @james_n and @hungryhalibut
I just wanted to make sure there would be no issues.
Apologies HH for my incorrect terminology… at least you knew the lead I meant
I’ll be interested to see what you think. I borrowed a 250DR from my dealer to try with the Nova as I thought (think) the speakers could do with more beef but have to say I was underwhelmed.
But others have had a more positive experience. I have found switching to a SN3 and moving the Nova to other duties more satisfying (and ultimately more expensive!).
