Hi all! Quick question: I currently have an NAC 112 powered by a Flatcap 2 with an NAP 150. I have a Martin Logan Grotto powered subwoofer connected by a Naim 10 meter cable (I assume “slugged”), and was instructed at the time (20 years ago) by the Naim dealer I purchased it from to connect it to the 112 via Signal Out B.
In preparation for possible upgrade to a 202 (which doesn’t have a similar secondary Signal Out), was going to switch the subwoofer connect to the Flatcap via its Signal Out B. Would that have the same type of connection as from the 112?
Thanks!
