Connecting Radio to ND555
How do I connect the radio player to my ND555? It only plays on my phone. Have been into settings but getting nowhere.
I find the changes very confusing and can’t play my system!
Very annoying!
The radio player thing is exactly that - something that allows the services to be played on your phone.
In the app, select the ND555 from the list of devices (below the radio player thing) and use the app as normal. If the ND555 isn’t in the list of My Devices, then that’s a different problem altogether.
You could connect the radio player to an external device using Airplay, but there’s no point: you already have the same radio service in the iRadio input in the app for any Naim streamer.
Thanks guys. Makes sense now. It’s just a way to access your favourites on your phone, but doesn’t connect to your streamer.
If you can’t make that work, you could pick up a WiiM pro plus and use as a radio source. I have one that feeds into a Naim Dac and then into my Supernait
Great piece of kit
He doesn’t need to, he has a Naim streamer that has the same iRadio built in.
