Connecting Uniti Atom to PC through USB
Hello there,
I am bit confused if I can use the uniti atom by connecting it to my pc through a usb cable. if not I’d like to know why not seeing that it handles a USB stick just fine.
Best wishes :slight_smile:
Hi, you cannot connect to a computer via USB. You can use a network connection, or SPDIF. Streamers are primarily intended to be network devices, which begs the question, why do you want to use a direct connection from a PC?
