I am a bit unsure how to connect the hi-cap to my supernait 2, on the diagram, it looks like there are 2 cables from the hi-cap to the supernait 2, do I need 2 cables, as there is only one cable with the hi-cap
Yes you need a second snaic. The one that comes with the hicap is a 4 pin one, you need a 5 pin one in addition.
(Or it’s the other way round, I can never remember).
As Robert says, you need both cables. The Hicap comes supplied with a SNAIC5. You need to buy a SNAIC4 to use it with the SN2.
See I always get it the wrong way round!
Ah I know how to remember it; the 5 pin takes the power so that’s the one in the hicap box.
So just to be clear, I need to use 2 cables, SNAIC5 & a SNAIC4
Yep. The SNAIC4 used to come with the DIN4 equipped Power amps.
Yes.
Thank you both for your helpful advice, much appreciated
If the are any left, it still would…
Yep.
