Hello all, so advice guidance would be great.
Please excuse my non technical thought process
When using my naim products I mostly use the Naim app on my phone and start any commands with the Uniti
So my issue is connecting my Naim UnitI to my Naim Mu-so in whilst listening to music through my laptop or phone via bluetooth into the uniti.
So initially I had purchased a Arcam I-blink bluetooth device connected to analog input in the Uniti, no problems connecting my laptop and phone to the I-blink and playing through the uniti, now because it’s through the analog input on the Uniti I cannot connect my mu-so in multi room , is that right ? Analog means no multi room?
So after seeking some advice from a local hifi shop, recommended was purchasing a bluetooth to digital device to go into a digital input on the uniti would sort that problem out , unfortunately not…
I purchased a IFi audio zen blue V2, connected it to the uniti in the digital 2 input via a optical cable , once again no problems connecting my laptop / phone to the V2 bluetooth and playing music in the uniti digital 2 input … all good but still I have no option connecting up with the Mu-so , no multi room option is coming up on the app…
I thought the digital input on the uniti would let me then connect easily to the Mu-so , frustrating
I know that both systems are connected to the same wifi network
I also tried the Mu-so on the digital input with no luck
I know the multi room works perfectly when using I-radio
Phew I hope all the above makes some kind of sense and someone can point me in the right direction , hopefully it’s something simple that I have overlooked…
Very very much looking forward to a reply…
Many many thanks Tone
