Yes, that’s right - and looks as if you’re logged in (being as it’s giving you a login input).
If you then go to the TIDAL logo on your home screen, you should have access. Or trying searching for a favourite album and artist - that should bring in TIDAL search results.
Only Spotify appears on the front display, as it’s a compliance feature of Spotify Connect.
Going back to your connection issue, I would suggest you reboot your NDX 2 - fully disconnect from the mains power, then leave for 30 minutes and restart. Also fully close your App during this down time - maybe restart your phone/tablet for good measure, too.
If you’re only getting the start of a Qobuz song, it usually means you’re logged into another device - unless you have the Family subscription, Qobuz only supports one connected device at a time. So if you log out on your phone or whereever else you have an active Qobuz connection, it should stream fine from within the Naim App
In that case you’re probably just getting 30 second mp3 samples from Qobuz. You can always hide Qobuz by going in to the Naim app settings → Input settings → Qobuz and disabling the input
I am always logged into Qobuz on a tablet and a phone with the Naim app on both (actually both the release and the beta app on both), and on the phone with the Qobuz app too, and sometimes with the browser on the laptop, and never had any problems. No family subscription.
Based on forum posts I saw, the 30 secs seems usually an issue with the login not actually having worked although it looks like it. Logging out and back in typically seems to fix it
Edit: Or not actually having an account like rob-z …
Users with multiple active devices - eg several actively streaming at once - have encountered this exact same issue in past. And having no account, evidently!
