Hi Folks,
I bought one external hdd for uniti core backup, I plugged it to PC after the backup finished but the PC cannot read the HDD, is it normal ?
marcobb0312
Hi Folks,
marcobb0312
You should be able to read it with a PC. When you set up the HD in the Naim app for the backup, what format did you choose?
Best
I chose NTFS, thanks David.
NTFS is right for a PC of course. Can you try another PC?
Best
Hi David,
Yes, I had tested on other PC but same result and I asked my friend, he also has the same result.
Marco
I can see you are not getting much help from us here. I suggest you ask Naim support if they have any ideas.
Best
Hi David,
I had other problem and email to naim support but no reply from them over a week.
Marco
