Argh. Have followed advice in here to turn off a disconnect - twice - and it is still refusing to eject a cd, on which it did not start the ripping process. Any idea how to force it to work?
There is a small pin holeā¦ā¦you need to press really hard with a paper clip and it will eventually eject.
Erm there want actually a cd in that would explain it.
Idiot (me)
I am sure by the end of the day i will do something even more stupid, i just wonāt fess upš
Brilliantā¦!
Is almost as bad as my panic the other day when I thought my Statement had been nicked from the houseā¦.then, after a while, I remembered I didnāt have oneā¦.!
SC
Thank heavens that you donāt have Statement system or something similarā¦
Just in case itās ever helpful to someone reading this thread, you have to push really hard several times, as itās a mechanical ejection, not triggering an electrical one as you would expect.
Yes, almost to the point of thinking you might break itš¬
Interestingly, when we were beta testing Core firmware a couple of years ago I had to do a manual eject and Will told me that I should take the power off first (āfor safety reasonsā). I didnāt mention that I had just done it with the power on!
