I’ve created a wiring diagram of my active system from the Snaxo to the Speakers and twisted myself in knots. Can anyone confirm if this is correct?
Thanks in anticipation Pete.
That looks a perfectly understandable wiring diagram Pete. Can’t see an issue with that.
Thank you James … always best to check !
Pete
Hi James the diagram was to send out to REL, Naim and Chord who are looking into how I can best connect a sub to my system hence my concern that I had set it out correctly. I’ll let you know how I get on.
Cheers Pete
That’s a good plan Pete. Good luck
