Anyone had a problem with SN2 outputting crackles at high frequency??
You can only hear it if you place your ear onto the tweeter
Disconnected all sources and replugged mains into another mains socket and it still happens
Tried removing all Dins infact all inputs except the speaker cable and mains plug
I may take it into the dealer and get them to stick it on a scope, and yes both speakers
Cannot remember but the dealer delivered the speakers and supplied the Naim system and I asked about the cables and he said they are fine and go well with both.
Flat cables
