Hello to all of you! What are the advantages and disadvantages of the SRC function in DAC V1? It is difficult for me to understand and use it. For which sources is this function used and for which sources is it not recommended? More details and concrete examples please? Good luck!
It’s for coax digital input via spdif where the source component is out of spec. with respect to the clock.
In other words, if you dont have any issues listening to eg a cd player via spdif into the dac v1, then dont change any settings.
