DAC V1 audio Driver
I wonder if anyone has run into challenges with the Audiophilo driver for this venerable but very good DAC. I recently moved over to Audirvana to have the benefit of its excellent integration with Qobuz As a result I noticed that the driver was restricting data rates to 96K and could not be adjusted from within either of my media players. Having read a few comments online I thought it would be sensible to reinstall the NAIM driver. Big mistake, Windows 11 now tells me that since April 2026 it no longer meets its security requirements and will not allow it to be used. Although it shows in the device drivers, it is inoperative and invisible in the mefia players.
When I first moved to Win 11 I checked with Naim support to see if there was a new driver and was told it wasn’t going to happen, so I assume Naim will not update it for the latest security requirements either. I wondered if anyone had any suggestions to help me get back to being able to listen to my large download library short of buying an new DAC?
TIA Colin
I think you will by now realise you are on your own with the V1. I had one and found it fine. It had its vulnerabilities, the screen being one and reliance on drivers another. I swapped it out for a regular nDAC. I take it you are using the V1 via your PC exclusively?
Your best bet here is to run Linux as your OS. Linux supports both Audirvana and the DAC V1.
If you don’t want to replace win11 on your PC with Linux you can install Audirvana on a raspberry pi running linux and use the android remote on your PC (via an emulator)
Hi, Thanks for your thoughts, I agree. I guess my Ire was with Microsoft. I bought a new win11 machine because they were terminating WIn10 support (which they then rescinded) and then they obsoleted my NAIM DAC. I think I would generalise your comment to say, I’m on my own with NAIM and MS is not really that interested in being a streaming platform for us Hifi lovers.
My Win10 machine still works, MS’s security check seems to be done on installation, if you loaded the driver prior to April 26 it seems to let it alone and it runs at 384K. It is a trifle slow though it has to be said even in stripped down form
I use the DAC for my CD player and via an ADC for my phono input.
Looks like I’ll have to put my toe into the Chinese Hi-Fi waters, they seem to have perfected DACs at very reasonable prices. Shame, I love the sound of the NAIM and I’ve never had a moments problem with it in 10years
Thanks again
Colin
Thanks both. Yes great idea, I may well go the Linux route when MS support for it terminates. I haven’t used Linux in 30 years so it’ll be interesting to see how much better it is. I guess choosing the right distro is key :folded_hands:
No drivers needed for a Mac either.
Nor for any of the inputs you also have on the NDAC, i.e. SPDIF. It’s just what you need on a USB DAC.
Colin, before giving up on the DAC-V1, there might be another way to keep using it with Windows 11.
The V1 has optical and coaxial S/PDIF inputs as well as USB. If your PC has an optical output, you could connect it directly to one of those inputs. Otherwise, a Windows 11-compatible USB-to-S/PDIF converter could do the job without relying on the old Naim USB driver.
You’d then select that digital output in Audirvana and switch the V1 to the corresponding input.
The one limitation is sample rate: the V1 supports up to 24-bit/192 kHz over S/PDIF, compared with 384 kHz over USB. But that might be a reasonable compromise if it means keeping a DAC you still enjoy.
Does your new Windows machine have an optical or coaxial digital audio output?
AI assistance: ChatGPT helped draft this reply. The connection specifications were checked against Naim’s published documentation.
That is an interesting idea.
Something that could work in this scenario is the Topping D10s. It can work as a USB powered DAC but I use it as a digital bridge - it has a USB input and both optical and coaxial outputs as well as RCA’s. It works effectively for me to act as a bridge beween computer based sources and my AVA Media Amplifier that only has SPDIF inputs.
If I get a chance I will test mine between a Windows 11 laptop and my own DAC V1 and see if it plays higher sample rates (up to 192). Coincidentally, I have recently noticed that my DAC V1 does the same as the OP’s when receiving anything above 96khz from Tidal via a laptop. It is OK with some rates and not others. I assumed I needed to do some form of update somewhere (or run bitperfect) but perhaps I am best to leave it alone?
You will never get from them what you had with Naim—not even close—so keep that in mind.
In my view, it’s best to just leave things be; to share my perspective, expectations for Hi-Res turned out to be inflated—the “Red Book” standard is fine as it is.
Thanks all, there are some really great ideas here and I’m grateful for all the useful inputs. I’ll research which options make a good way forward. My new machine doesn’t have SPDIF or optical outputs sadly. A convertor is a good option to check out though and the DAC is well equipped with inputs. On my Win 10 system I typically do run up sampling to maximum data rates but I guess the gains over 192 is going to me minimal.
So, I have some food for thought to keep me busy during the dark months of winter
Thanks again all
Colin
