Hi everyone.
My DAC-V1 issues an “DSP Boot Failed.” upon starting due to an update firmware error.
Apparently the update process failed.
How can I resume firmware updating from a “dead” device
Can you help me with this?
I had a similar problem way back in 2013. Naim headquarters recommended this to my dealer, and it worked:
"Turn the DAC off first, then: “Press and hold 1 & 3, then turn on the unit. This will display “Forcing DSP update” then start updating. Once complete his unit should function normally.”
Could you use this method to downgrade the firmware, thanks
That procedure is designed to force an upgrade that has stalled. I assume you would need a copy of the older firmware to revert, and even then, there could be problems. As I recall, there was an uptick in sound quality, and no downside.
I wanted to note that the reason for the erroneous update is FOOBAR, but with JRIVER MEDIA CENTER everything works correctly.
