Hello Brains Trust, My DAC-V1 has developed an error where it insists that it is downloading a firmware update. I can’t remember the details now, but my dealer suggested that I begin by downloading the latest firmware version and updating it. The link on the Naim website for the file contains no files. https://dam.focal.com/pinaccess/pinaccess.do?pinCode=R6dqmJijK9Dd . Ideas, please? Thanks!
The last update for the DAC-V1 must have been some time ago, I can’t remember now…
I have one (back in the UK) and sold another one I had here in Australia….I’m fairly sure I will have the download saved somewhere as I tend to keep copies of such things – if you get stuck sourcing it I can set up a link for you to download….But I would think if you get in touch with Naim support they should be able to sort you out….
SC
I have a copy of v1.16, which I believe was the latest(last) firmware…
It is something of a pain to upload and apply, but fairly straightforward once you know how to…
If you need the file and/or don’t get sorted via Naim, let me know and I can give you a link…
SC
^^ bit perfect test files
^^ 1.6 firmware
