Hi all,
my Naim DAC V1 screen shows:
“DSP update failed. Updating again”
How to solve this problem?
Thank you
Hi all,
Thank you
Try the following:
"Turn the DAC off first, then: “Press and hold 1 & 3, then turn on the unit. This will display “Forcing DSP update” then start updating. Once complete the unit should function normally.”
Thanks, I did it. but it showed “Forcing DSP update”, but nothing happened after that, is there anything I can do
In that case you should raise a ticket with naim support either by phone or email.
For help with all Naim product installation and operation please use the following details:
support@naimaudio.com
T: +44 (0) 1722 443405
Hours of service are Mon-Fri 9:30am-5:30pm GMT/BST
OK, Thanks
