Hi
I would like to setup a direct usb connection between dac v1 and synology using audioquest cinnamon cable and ds audiostation as a player.
Are there some experiences in the forum?
I assume audiostation bitperfect am i correct?
Thanks a lot
Have you looked on the Synology ‘Knowledge Base’ Its all covered there.
Yes i did but i m not interested in it topic, i m interested in audio experiences.
OK, I suspect you won’t find many.
Thanks mike, i suspect too but i would like to know if there are many that tried and were unsatisfied
