I think you are. Logic says it has to be working as DG says. To connect two amplifiers to the Kudos 606, the metal links on the back have to be removed. If standard biamp was connected, both bass and treble drivers would receive full range signal and the tweeters would instantly fry.
Nothing fried with people bi amping they still get full range.
Thatās what Iām trying yo ask are the outputs frequency dependant or not.
All bi amp systems are full range itās only cut down by electronic crossover that isnāt.
I know, but in passive biamp you still use the passive crossover. By removing the links on the back of a Kudos 606 you bypass the crossover. Connecting biamp will fry the tweeters, therefore the Linn must be splitting the frequencies. Anyway, Iām not sure why we are even discussing this; if Linn says itās active, Kudos says itās active, Cymbiosis installed it as active, itās clearly active.
Thanks everyone for chipping in, learning lots which is a great help understanding how systems get put together.
I only asked if the amp split the frequencies.
Removing the links is the same as removing plates itās only access to that part of the passive crossover.
Unles the frequencies are split to match the drivers then it isnāt Aktiv itās wonky Aktiv
And if the passive crossovers in the cabinet arenāt disconnected completely it still isnāt Aktiv
Simple. ![]()
Just because someone calls something a name doesnāt mean itās right.
Stay away from Naim Active systems if your goal is to avoid multiple boxes, cables, and interconnects. Addictive sound but much more complex set up. Naim speakers were designed for active and passive use back in the dayā¦
Been there and done it all multi boxes and got rid and went minimised.
This is what the Kudos website says.
There are two things to note, which support what I wrote above and which for some reason you choose not to believe. 1. Removing the links bypasses the crossover. Itās not like removing biwire links on a standard biwirable speaker. 2. Exakt can enable active operation.
Thanks for taking the effort with the info but still seems a fudge to what is properly Aktive not just multi amp split.
All I wanted to know was did the amps put out in different split frequencies.
I thought that was a simple question but itās replied like politics.
Iāve had passive and multi amp and active ā real ā but this seems like a collection of gobbledygook avoiding the real question and renaming something for the sake of sounding technically superior.
Iād love to hear the treble outputs connected to the bass with the bass leads removed. ![]()
Oh and Exakt isnāt a crossover itās a speed matching software technology not frequency splitting.
I think a key question regarding the Linn Approach is whether you can separately adjust levels and phase (timing) of bass/treble, and if relevant mid, power amp modules relative to each other, and crossover frequency(ies) and filter slope(s). Or does the Linn SO definitely do all that when particular speakers are selected in its list, having that info already in its memory bank? (I ask because last time I looked at their SO, a few years ago, it appeared to just tailor frequency response to get the best out of different speakers.)
The one thing I want to avoid is a big box count, at the moment I have TT/Power supply/Phono stage/CDT/Amp then obviously out to speakers, 5 boxes, 5 plugs, 5 mains leads, then all the other cables.
Hopefully through these discussions I can come up with a way to get the box count down whilst improving the overall SQ. So far it has been very enlightening.
The answer is āyesā⦠I donāt do politics⦠![]()
Thank you.
What are they afraid off. ![]()
Thats very right, there are however small active setups possible.
One thing Iād like to try is:
Nait 5 (pre amp and power amp splitted)
Ixo (LF to Hicap / Nait 5, HF to Nap 140)
Hicap
Nap 140
⦠into IBLās
Thats an active setup which probably will let the IBLs sing. NDX2 would be the appropriate source I guess ![]()
Thanks for the clarification. I hadnāt realised that the crossover in the Kudos 20As could be bypassed. I guess thatās what the āAā stands for. Doh!
Roger
Thereās some info in the FAQs on ATCās website about what they see as the advantages of active operation which might be worth a read. For me, quite apart from box count, active, or at least ATCās implementation of it, brings something a bit special to the party which I find addictive. But we all prioritise different things in our pursuit of SQ and as I suggested above the result does not appeal to everyone. Auditioning where possible is always the safest way to choose.
Do keep us informed how you get on.
Roger
Slightly off topic but when I was at ATC, discussing various active approaches, Richard Newman (engineering manager) spoke about some ābrand Xā actives that they reviewed that used DSPs giving interesting results. A wide left to right separation but an uncomfortable overall effect. This was described as no depth, forward to back presentation.
I didnāt ask further questions regarding this approach as I always wanted fully analogue active speakers.
I would be very surprised if ATC are not evaluating DSPs, they seemed to be experimenting with everything else but I doubt they would promote them until there is a significant benefit.
Paul.
Yep you understand it completely
If you want the benefit of active with low box count there are other options besides active speakers.
- Single driver full range crossoverless speakers. You wonāt need an active crossover or even a separate pre and power amp. The benefit of an active system is less the active crossover and more that the amplifier is directly coupled to the drive units without a crossover. I actually do this in one system.
- Multi channel amplifiers with active crossover. For example Daniel Herz integrated amps have an onboard crossover and four channels of amplification.
We are currently in an age where there is definitely many ways to skin the proverbial cat.
Letās not forget passive crossovers have massively improved as have amplifiersā capability to deal with them. Many high end speakers offer no active option at all.
Iād say active os a cherry on top rather than a goal unto itself. You have to like the speakers passive first. As such, Iād never restrict my choice to speakers that have a way to active.
I donāt think thatās ATCās view. In their FAQs they first highlight the ability to control level and phase independently and the major benefits that brings to stereo image stability as a significant advantage of active operation. It was indeed that aspect that first drew me to their active speakers. Of course, weāre all different, thank goodness, and imaging may not be of prime importance to all listeners but itās a key part of what draws me into their sound world. I rather doubt Iād have built a system round the passive versions of my SCM 40s.
Roger .
