Dave came round
Yes if you had a dCS Network Bridge, which did upsampling then the effect of mScaler might be not be so great. I have tried a Linn DSM, Sonore μRendu, Mac mini & Asus Laptop. No discernable difference between without DSP. I prefer Mac mini & Asus Laptop because you can set JRiver Media Studio DSP so sound quality is improved and the user interface is superb using JRiver Panel.
:small_blue_diamond:It is very easy to understand,.they hear things that you do not hear…Simply as that :+1:t2:.
/Peder🙂
But with the mScaler Sound Quality improves.
You can measure the effect too.
If you have not tried mScaler then give it a go.
You’ll probably find your system is only giving 70% of its potential performance without it.
The mScaler with DAVE takes digital replay a step forward for me. It was really easy to install. I use Canare cables with ferrites as specified by the designer and it sounds superb. I find using a fully balanced (XLR) connection between DAVE and power amp optimises sound quality. I wasn’t as happy when I tried single ended (RCA) ICs (same is true in my Linn system). I use Canare Star Quad ICs.
When I play Anthony Phillips new CD set, it sounds as if this wonderful ex-Genesis guitar maestro is in the room.
Forget the tweaking and enjoy the music.
Well that’s my philosophy.
