It’s been quite a while since the last DBLs dedicated thread, to have a look at all those besties still around going strong. So please, all you DBL lovers here, share you favorite DBL pics and systems.
Some may remember my thread a few years ago refurbishing my Rosies. Meanwhile everything got moved to a new house, more or less finished now. The cherries I couldn’t resist to buy some time ago and they have been refurbed as well except for the tweeters. That’s why I currently run them chimeric with the Rosies on top of the cherry bases.
How does the substantial NAC S1 (?) make its presence felt in the system compared to the old preamplifier? An absolutely dreamlike Naim system! Thanks for sharing it.
This year I refinished the laquer on mine having learnt more about spraying it. However I picked up some amazing veneer last week. Which may get me on the path of refinish again. A bit mad I know but I love it. The wife says its too dark and she may be right.
One thing that I have long wondered about the DBL concerns the tweeter and mid. AIUI (but I could be wrong) these were, essentially, the IBL drives and setup. If so, what would happen if you swapped those for the SBLs?
Very beautiful and soo shiny indeed. Seems you have done all the homework necessary to keep them up and running, reconing the bass drivers and replacing the foamings inside as well ? Seems also you have replaced the tweeters with the successor from scan speak? . How did you modify the suspension plates from original four drillings to then three? Or did you find somebody to make new plates for you?
Are you running them passive ? Have you thought about servicing the POX as well ie exchanging the elcos?
Many greetings Charlie
I got very very lucky on the bass drivers. TomTom audio had a pair BNIB these are from 2020.
The tweeters are indeed a replacement. D2104/712000 Dome Tweeter
They have the same sound signature but do require a tweak to the cross over. The plates I had made at a local metal company. The wave guides are 3d printed. The guides are hollow and filled with stainless steel rings.
I run passive. The cross overs I hand made (With tonnes of help from someone that knows what they are doing lol)
They cost a lot of money, I dread to think what they would be retail. Each driver has its own board.
Here they are, although have changed a bit since this photo
@Charlie The Rosie mid boxes looks lovely !
I have these Piano Black,I like them because they
reflect the walls which make them look a little less boxy and also that the black grilles integrates well.
Active Snaxo 362 6x135’s
Thanks for sharing. Your custom made Poxes are quite impressive. Seems you have spent an enormous amount of effort and time to custom build these. .
Back to the tweeters
There seem to be a few alternatives for the original
D2010/851100 which are no longer available.
Alternatives seem
D2010/852100
The one you are using now
D2104/712000 albeit with the necessity to change the settings if the crossovers
And apparently some from Hiquphon
OW1-98 or OW2-98, anyone here having experience with them?
The mids remain an Achilles heel. I found some scan speak some years back Discovery 15W/4424G00 that would match the sonic parameters but haven’t tried them myself. I think to remember some chap from the forum here, however did install them, I think it was @Willy
ATC I guess still offers a reconing of the original bass drivers.
The piano black really looks stunning, great to see another active dibble system. Did you replace the foam grilles at some point ? Unfortunately they are no longer available, and the originals have desintegrated and became dust long time ago . Tom Tom had some on offer, but that’s at least 5 years back.
