Without going into anymore detail would any members like to share their opinion of the vocal quality of this track, I have an issue just trying to work through it, many thanks in advance .
I like that track very much . Have the high rez Qobuz and the voice sounds very good to me.
Tried the Tidal 16/44.1 just now and his voice is clear as a bell.
Can’t say I like the vocals.
Sounds like the musician are close by, with the vocalist shouting from a distance away.
Sounding very fine to me on Hi Res Tidal
Are you on 3.10.1 firmware for Nd5xs2? Do you hear some sibilance, harschness?
Sorry for the late response, from start to finish of the track the vocals are a mess, harsh, edgy full of sibilance.
To answer your question regarding the update we are on the latest version and I woe the day I downloaded it, system has always been on the edge at times but now the latest firmware has totally tipped it over the edge, unless the track is really well recorded.
I guess you are following the thread about it. What a mess .
Yes on both counts😉
Listening to Chris Stapleton’s Death Row song via Qobuz (96/24) and find no issues with his vocals or music.
I have had no problems with the any of the software updates.
System: XPS DR > NDX 2 > Hi-Line > SuperCap DR > NAC 282 > NAP 250 DR > NAC A5 > ProAc D30RS – also: C2960C-8PC-L Cisco Catalyst Switch, English Electric 8Switch.
I use a fifth generation iPad and a iPhone 8 with the Naim App to play the music.
All I can say is you are very fortunate I wish I could say the same.
Disappointed would be an understatement, after nearly 3 years of putting together my system I can’t believe it can sound like it does at the moment.
Sounds fine to me, now giving the whole album a listen (Tidal Connect 24/96). Using a Nova with latest firmware and AQ Power cable → Witch Hat N2 cables → Spendor A7 speakers. A basic ethernet cable attached to a basic switch (D-Link).
Glad your system sounds okay mine did until the new firmware update , it’s just not tolerant of any edge in a recording anymore, just hopeful that Naim will sort this issue out.
NDX 2 + XPS-DR & SN3 + HCDR here. From Qobuz → Roon, Chris sounds superb with no sibilance at all.
Hopefully soon I may experience the same result as everyone else, if not I guess it’s time to take up golf😂.
Buy a Primare NP5/ifi power supply for £600, sell the Naim streamer for £1500.
Problem solved and money to buy golf clubs.
On ND555 with current firmware, via Qobuz, the vocal sounds fine to me. I have had problems with higher frequencies, as for example female vocals and violins, but not to the extent that some have.
Streaming through headphones through non-naim gear. Sounds fantastic. Very spacy, great depth in the recording and no harshness at all.
Sound fantastic. Sounds like he’s singing/recording in a large room.
I’m not hearing that - vocals sound clear, sharp and no sibilance. Sounds like a great recording. If anything the vocals are a tad back in the mix.
