Are Deltron banana plugs any good for amp end on naim amp.
Yes.
No nonsense decent quality connectors no ripoff.
Reason is i am adding a rel sub and the naim duals are the wrong shape for piggy back with the bass line blue naim cable.Thanks for reply
Yes, same side spring tension design as the Naim pins, truth be told, the Naim pins are the same design as the original Deltrons.
Those stackable plugs look a bit messy to me. I dare say they work, but I think if I ran a Rel sub I would be cutting off the plugs and soldering the sub cables into the same sockets as the main speaker cables.
Something like this:
Photo courtesy of @Adam.Meredith
