If I download and install this updated DTC, is it likely to bugger up the settings I have with the NAS, so kindly done by Tony??
No not at all. It just runs as a separate program on your PC. It’s like another pair of binoculars…
Best
Thanks David. Seems to have done the job but note that previous version require to be uninstalled first. Just trying a differential backup to see what happens but all settings appear intact.
Thanks for your input David. It appears to have done the job and no warnings now on the version eitehr! Many thanks
Owen
Well, you learn something new everyday!!!
Yes you always have to uninstall the previous version. Anyway I’m glad it works for you.
Best
