For some reason I can’t dim the 4 buttons on the ndx2. When I press the dimming button (the sun button) on the control nothing happens. I’ve tried turning it off and in again and have also done a factory reset . Can’t think of what else to do . Is it likely to be a problem with the remote? Can anyone help? Thanks
Thanks but that only turns off the display - I’m trying to turn off / dim the leds in the 4 buttons . The sun dimmer button in the remote control isn’t working
Does that setting make any difference?
Just checked it on mine and the remote
button cycles through the brightness settings.
You could try doing a reset and re-pairing the remote?
Presumably the remote is working otherwise?
Tried that too
Yes that’s right
I know a couple of other members on here had the same problem but I don’t know if they managed to fix the issue
Strange, maybe try a power cycle
Thanks , what’s a power cycle?
Power it down, pull the plug out, leave for a few mins and power up again. Also try removing batteries from remote and reinsert. Edit, maybe try fresh batteries too
Thanks will try that now
Tried that but makes no difference
Maybe the button on the remote is a little sticky. Have you spilt any liquid on the surface in anyway?
No it’s brand new , just taken the wrapper off it
Talk to your retailer, then.
Thanks, very helpful
Could be just a faulty remote, ask your dealer to lend you another
Try removing and reinserting the batteries on the remote. Mine was playing up the other day and that fixed it.
