When conecting a Naim amp to a non Naim source with an hiline int cable what kind of bananas are used.Is there a Naim standard.What is expected to be done by a Naim dealer with a din din hiline to solve this matter.
If you mean the RCA to DIN Hi-line then Naim use special locking WBT Next Gen RCA phonos.
AFAIK DIN-DIN Hi-lines can’t feasibly be modified to RCA, so if you have a DIN-DIN Hi-line but need an RCA-DIN then your best bet is to sell the DIN-DIN or try to look for a trade-in with your dealer against an RCA-DIN
Fully understood.Thanks
