I have a CD5X & Flatcap connected to a Heed Obelisk Mk3 using a Van Den Hul C5 The Bay RCA cable.
Would I get better results using a Din to RCA ?
In my experience with Naim equipment I’ve always had better results using DIN plugs, even with DIN to RCA. I haven’t used a CD5X though.
If you use the same type of cable, probably yes.
However, the cable itself is more important than the cable termination.
I was thinking of something around ÂŁ150 for a Din to RCA, maybe an Audioquest Big Sur for example which is around that price point.
Are there other cable recommendations in this price range for a Din to RCA?
I would use any Chord Co option that matches your budget. DIN to RCA. Anything but VDH on Naim which I suggest you will agree with when you hear it.
@ink04 VDH Can drive Naim into ovulation if used with Naim I heard.
Then the Naim has babies, Nait 50’s!
Think you mean “oscillation” ![]()
@TeeDub21 yes sorry
No you wouldn’t.
You could do worse than Naim’s own cable. A bit under £150 at present, I think.
Roger
@ink04 might wish to have a look at the following topic first, though…
I assumed the OP was looking for new.
Roger
The linked topic is discussing the fragility of the Naim Lavender RCA-DIN cable, irrespective of new or used.
Presumably you’re talking about speaker cable used with older Naim amps.
The OP is using a Naim cd player and a non Naim amp.
Yes, marginally.
As I have written many times down the years on the forums (fora) pressure contact interconnects are a weak link in signal integrity. Phono to Phono has 8 pressure connections. Phono to DIN has 7… it’s not much, but tangible and factual. DIN to DIN is 6 and better still, that is a 25% improvement in performance all other things being equal compared to stereo phono to phono.
I’m unconvinced that a few bad experiences really mean the lavender cable is especially fragile when used with care. It certainly doesn’t look that impressive but it’s SQ that counts and unless I missed it there is no comparison of SQ, which is always the overriding factor in Naim designs.
Roger
As a DIN to DIN version the stock lavender cable is fine and quite robust and can be heavy handled, but with those quite heavy RCA plugs on the end of it is not. Very delicate in fact, almost borderline with a HiLine on those terms.
