DIN gives a clean Earth, the way that Naim design their equipment is not using a Chassis Earth, the audio part of my system Earth is via the headshell on my record deck.
The chassis is obviously Earthed to the Mains Earth, for safety reasons, but a floating Earth improves the sound quality. Some Naim gear allows you to select either floating of chassis Earth, move the switch hear the difference.
Yeah havenât played with it in my main system as I only have one real source⌠switched to chassis. My second system doesnât have the switches so floating earth has always been a bit of a mystery to me. Though it sounds exciting!
Guys, is there any good XLR to DIN cable?
I have IFI PRO IDSD DAC with XLR output. I want to connect it to my SN3 amplifier. I currently connect it by RCA to RCA cable. I wonder if XLR to DIN will sound better
Atlas and Chord can all make such a cable up and it will be as good as any. But unless you are forced to, DIN - RCA would be superior over DIN - XLR. XLR really only comes into itâs own when both ends are balanced and generally only over longer runs >1.5m (YMMV).
If one endpoint only supports XLR you wonât have much choice of course. But honestly, donât mix XLR with an unbalanced endpoint unless you have to. Itâs the worst of both worlds.
