I recently aquired an nDac and am absolutely loving what it has brought to the table compared to my old v1. A gripe I have is that there does not appear to be a way to disable the input button light or the sync/HD lights - is this the case or is there an incantation to disable the lighting?
Obviously hardly the end of the world but it’s a minor gripe visually as I run with lighting disabled on the 202, and it’s usually considered good hygiene re: audio quality.
You can disable the illumination of the input selectors but not the sync/HD lights. I think you can do the former from the remote you have for your 202.
