‘Disc contains no tracks’
Hi
I joined the forum because after two years my Uniti Star has started displaying a ‘Disc contains no tracks’ message when I try use the ripping function.
Has anyone else experienced this?
Where is a good place to look for advice from the manufacturer about what to do?
Kind regards, W
Here you go;
But first, have you tried a power down “re-boot”? (power down, pull mains plug out, leave for a few minutes, then plug in, power up, go and make a cup of tea to let everything sort itself out)
Hi Richard
Thank you for replying so quickly. I have tried those things but the link is really helpful.
Best wishes, Andrew
Update, after some searching I found the troubleshooting diaglog box using the link, typed my inquiry, pressed send and got a 505 error message. I’m going to ring Naim and then will update again ¦-|
