Hi to all, Right now I’m listening to the radio on my Nova and the display is showing the station name, but there is an alternative display which shows more information which does appear but then it changes to the station name so I was wondering if I can keep the other one on all the time ? I’ve tried to find out how to do this but can’t seem to find a solution…
The other problem with just seeing the logo is when the logo is all white. It lights up the room at night like a flashlight. Yes I know I can cover it, but come on….
We used to be able to turn off the display but now that’s gone.
It never went. My remote can change the logo intensity on both a Nova and an Atom and nobody else has reported issues. Maybe you have an issue with your remote, but the firmware is fine.
I have noticed that the display mode changes when you put your hand close to the display, If it is showing the album cover you can see the track name by waving your hand close to the display. You have to move from your armchair to the unit:)
I quite like the screen switched on during playback- especially when the lights are off - it gives enough light out so I can safely lift and sip my glass of red vino… I’m still getting used to the white logo
