Hi all.
Do enyone have a clue? All play well, just display has such a horizontal lines. I even switch the display off, to save it for it’s longlife. Quite new hi-fi.
Have you tried forcing a factory reset and unplugging and powering up again? If it still does the horizontal lines, back to the dealer i would suggest. Never seen this before.
Yes, all tried. Now trying to worm up (leave on for few hours)
Playing few hours with display on, see some changes. Good for minute, than bad again…
My Atom had a similar issue a couple of months after I bought it, following a strange issue when I started it and heard some ominous popping noises. I was thinking it would need to go back to my dealer for repair or replacement, but after a restart it was fine. That was over 2 years ago, so hopefully it was a one-off.
I’ve seen similar on my Nova - convinced it was a display module fault, restart/brief power off did not help.
Unplugging mains for several hours inadvertently fixed it for me.
Still OK. Funny…
Before I tried to switch the display off in the app. Now, last 2weeks, is always on. Could it be a problem for display if this smart box plays with dark display?
