Diverse vinyl
Anyone here a regular user of Diverse Vinyl?
I ask because I pre-ordered a re-press copy the Kevin Gray Intervention Records issue of Billy Squier “Don’t Say No” from them back in May.
The Intervention Records site says shipping in “Winter 2021” as opposed to “Fall 2021” at the time of order.
I’ve bought a couple of Intervention releases from them previously with great service and communication. Just a tad concerned that I’ve sent Diverse a couple of emails to ask if they have a more accurate idea of the shipping dates but heard nothing back. Is all well at Diverse?
Steve O.
I had a delivery from Diverse on Friday.
Lindsay
Never had a problem with Diverse, been using them since 1996. Great bunch. I spoke to Paul last week about query I had with the forthcoming What’s Going On? reissue, so all seems too be good there.
Thanks for that both.
Yeah I just had a delivery from Diverse last week also. I’ve been using them for many years.
They can be a bit slow to answer emails but they usually reply eventually.
There are issues with vinyl production right across the board so delays are very common at the moment.
Pretty much every LP I’ve pre-ordered has suffered a delay and I’m accepting of that. However in this instance it’s the lack a reply from Diverse that concerned me.
I’ve got some LPs I ordered (not with Diverse) from as far back as May where I’ve not heard anything more since. However, I also know that it’s because of pressing delays. My experience with Diverse has been good, so I imagine that when they get a copy they’ll send it, and if they can’t get it, they’ll be happy to refund you. If you’re very concerned perhaps try calling them?
I too use Diverse a lot for my albums always had great service from the team and the pre release reserves has always workd as @TheKevster suggests give them a call
  • PRE-ORDER REPRESS NOW SHIPS WINTER 2021
  • PLEASE NOTE: DUE TO UNPRECEDENTED VINYL SUPPLY CHAIN ISSUES ALL PRE-ORDER SHIP DATES ARE APPROXIMATE
Yeah, saw that on the Intervention Records website. I contacted Diverse after “Fall” changed to “Winter” as both are more than a little vague.
Will phone Diverse later.
